BreakPoint
Ya know it's going to be a bad day when.....
You just got a new hard drive, just got everything re-installed and have successfully mass compiled your LabVIEW 8.0 directory.
You start LabVIEW 8.2 and start mass compiling that installation, only to discover (an hour later) that you are mass compiling the 8.0 directory. Smiley Mad
I wish the mass compile tool had a directory verification step.
Oh well, off to repair 8.0
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
Message 1 of 108
(14,926 Views)
Yes.... it does,,, it's the "Select Current Directory"!!  😉
Yikes!!  That's one of those times when you actually see a grown man cry!  😮
Message 2 of 108
(14,911 Views)
when you open someone elese's vi that you need to debug and you discover 30+ frames of Stacked Sequential Structures, where 1/2 the sub-vi have the outputs to the right and the other half have the vi outputs to the left.  This was probably done to simplify where the wires run to a sequence local.  However, midway within the sequence, the left outputs are routed to the right, and vice-versa..
The bad day part is that is the least of your problems!!!! here is an example
Message 3 of 108
(14,904 Views)
YKIGTBABDW- When you get a PM from Alphaindifferent smiley
Message 4 of 108
(14,899 Views)
yikes, bad memories being stirred up
Regards
Ray Farmer
Message 5 of 108
(14,888 Views)
A-man knows when to keep quiet..
Message 6 of 108
(14,879 Views)
The forums work better on IE than Firefox...
LAVA is down....Smiley Sad
OpenG is down....Smiley Sad
Ton
Message Edited by TonP on 01-31-2007 06:24 AM
Message Edited by TonP on 01-31-2007 06:27 AM
My LabVIEW Ideas
Message 7 of 108
(14,871 Views)
Works FASTER Ton 😉
"better" is a complete different ballpark... at least I feel more secure using Firefox... Smiley Tongue
Epictetus
Antoine Chalons
Message 8 of 108
(14,863 Views)
Well I just tried with IE, and that is definitely not working Smiley Very HappySmiley Happy
LAVA is up and running again.
OpenG is up and running again.
Ton
Message Edited by TonP on 01-31-2007 07:51 AM
My LabVIEW Ideas
Message 9 of 108
(14,864 Views)
Smiley Very Happy  Yes, LAVA is up, LAVA is up!! Oh joyous day! Smiley Happy
Michael Aivaliotis
VI Shots LLC
Message 10 of 108
(14,854 Views)
