BreakPoint
What is this used for??
I like old tools, and I bet more of us do too 😄
Today pliers No 1:
OK, last time I used it was about 7 years ago...and it's older than 70 years.. What is it good for?
Greetings from Germany
Henrik
LV since v3.1
Message 1 of 37
(11,973 Views)
Putting threads on screws/bolts etc?
Message 2 of 37
(11,950 Views)
Alternatively, DIY circumcision.
Message 3 of 37
(11,949 Views)
I would like to see a closer image of the jaws and how the are shaped but from waht I can see...
Crimping tool to put crimps in sheet metal like you find on one end of heating ducts so you can fit one into another
OR
Tooth setting tool used to set the width of the curf of a saw. Every other tooth is bent out out from center to ensure the curf is wider than the saw and prevent binding.
Ben
Message 4 of 37
(11,920 Views)
Well, what did you use it for?
Do you have a picture from the left side? Is the lower jaw flat?
Could be a tool to mark the ears of livestock (example)?
Something to cancel paper tickets?
Wire stripper?
Message 5 of 37
(11,900 Views)
Definitely too small to remove the horns from a Rhino 🙂
-AK2DM
Message 6 of 37
(11,882 Views)
Two more views
Spoiler
Ben got it 🙂
Henrik
LV since v3.1
Message 7 of 37
(11,876 Views)
 Solution:
Spoiler
here
I was suprised how fast you can cut a tree (quite silently) with such a like two men saw 😄
Henrik
LV since v3.1
Message 8 of 37
(11,870 Views)
Very impressive Ben.
My first guess was torture.
Message 9 of 37
(11,831 Views)
Confession time!
I was just guessing.
I own and use a modern smalled version after I sharpen my hands saws but I had never seen one like Henrik had shared.
Ben
Message 10 of 37
(11,781 Views)
