BreakPoint
What is this and what is it used for
I do not see the screwdriver tip that I would expect but I concur that one revolution of the "key" will move the count up one notch.
Still baffled as to what it turned where we would have to count up to 100.
Ben
Message 71 of 294
(11,032 Views)
@Ben, Jeff: It's a PMT , the Dynode arrangement is for higher speed. See http://www.hamamatsu.com/eu/en/product/category/3100/3001/index.html
James
no, it is not a screwdriver , and the shaft can rotate.
Greetings from Germany
Henrik
LV since v3.1
Message 72 of 294
(11,028 Views)
James
I expected the dynodes to be in-line with the electron beam.  You learn something new every day!
"Should be" isn't "Is" -Jay
Message 73 of 294
(11,010 Views)
New guess!
It is a rotation counter that can be used to count shaft rotation and when combined with a stop watch can be used to measure shaft rotation speed.
Ben
Message 74 of 294
(10,992 Views)
Yes, it looks like a mobile hand tool to measure rotation speed. Maybe some old steam engine or water mill has a hole in the axle where you would press this in for a given amount of time, then calculate the speed from the time and rotation count.
The tip looks like self-centering and tapered to prevent binding, but engages securely in a matching axle feature.
EDIT: Ben was a bit faster, but maybe we're both wrong :D)
Message 75 of 294
(10,990 Views)
Yes Christian see here.
A rubber tip like a pencil eraser would be attached to interface with the shaft.
Q: How long unitl a pencil shows up as the challeng in this thread?
Henrik,
Excellent collection you have there!
Thank you for sharing.
Ben
Message 76 of 294
(11,033 Views)
Nice video you found BEN 🙂  and yes, that an about 100 years old revolution counter.
Last year I found another pure mechanical one at an flear market in Capetown. The negotiated price was 150 Rand 🙂  (about 12$)
This one has the stopwatch included. If the shaft is pushed into the housing the watch is running. No matter wich direction the rotation is, the counter counts up. Resetting the counter by the red wheel will also load the watch spring. 🙂  And the rubber tip is also included, but only needed if you want to be nice to the wheel 😄
So here is a quick next one:
Henrik
LV since v3.1
Message 77 of 294
(10,961 Views)
Henrik_Volkers wrote: So here is a quick next one:
Works well with red (actually purple) or white (actually yellow)  items. Cheers!
Message 78 of 294
(10,919 Views)
Right Christian 🙂  It's always fun to hand it over to a guest.... 'How do you use THAT??' 😄
Next hint would be my old icon/avatar  ....
Henrik
LV since v3.1
Message 79 of 294
(10,910 Views)
Outlet tester.
Message 80 of 294
(10,892 Views)
