BreakPoint
Rube Goldberg Code
@smercurio_fc wrote:
@Jeff Bohrer wrote:
a few ways to skin the cat
Yeah. I just assumed there was a reason for the indicator being an I32.
Ray: is there something more going on?
I could not imagine a reason to maintain a I32 representation.  The sign bit is masked the lo(x) of a I32 is a U16 by definition.? Ray?
"Should be" isn't "Is" -Jay
Message 911 of 2,571
(11,091 Views)
For a simple indicator, the representation will of course be irrelevant.
Often however the value is used in further processing and the number of bits will matter. Without additional knowledge, we need to assume that the I32 representation of the indicator in the original code is significant. We cannot change specifications on the fly. 😄
Message 912 of 2,571
(11,088 Views)
(My emphasis). Indeed. For instance, if you had used the To Word Integer (I16) instead of the To Unsigned Word Integer (U16), then a value like 7AF123 would get you the I32 value filled up with Fs for the upper bytes (FFFFF123). Hence, in this case the representation of the indicator would matter, so to speak.
Message 913 of 2,571
(11,082 Views)
Thanks guys!
As soon as I saw Christian's example I went "AAAAAAAAAHHHHHHHRRRRGGGGHHHH!!!!!!!"
That was how I did it.  Even in C.  Deuh!
Not doing anything special.  Just braindead..
 Now I am convinced that I need to go outside, see the sun and get some fresh air.
Thanks.  At least people (and I ) will know that there are alternatives.
Kudos guys
The number gets converted to a double with some additional math afterwards.  Nothing complicated.  Two U16 are stored within 32 bit registers.  Hence the reason to extract the upper & lower 16 bits.
Message 914 of 2,571
(11,070 Views)
I forgot to mention that Jeff's solution was the chosen one 🙂
Now I go for a walk...
Message 915 of 2,571
(11,061 Views)
Well, then. Finally after 92 pages this thread has a solution! Woo-hoo!!! Smiley Very Happy
Message 916 of 2,571
(11,057 Views)
Ray wrote.
I want to extract the lower 16 bits of a number.
Lesson- read the spec.  never trust the original developer met the requirements.  Clearly a 16bit data type was the desired output.  Smiley Very HappySmiley Wink
enjoy the  sunshine
Message 917 of 2,571
(11,051 Views)
Since the word "extract" is too ambiguous (What does it mean??), I went with Ray's output representation as used in the snippet and which was hinted as correct, but just rube-ish. 😄
Message 918 of 2,571
(11,045 Views)
While AND is usually my choice for a masking operation (extracting certain bits), I tend to go with Mod math to split a number which seems to be the case here.
(Generalized version of Split Number)
Message 919 of 2,571
(11,034 Views)
The sunshine was brief  😞  Access to the station I am working on is limited..  Can't let sunshine get in the way..
Any of you guys in SC?
Jeff's purty good at extractin' the requirements... or mind-readin'
Message 920 of 2,571
(11,026 Views)
