BreakPoint
Rube Goldberg Code
@altenbach wrote:
@JÞB wrote:
@altenbach wrote:
Sometimes I feel evil. 😄
X(radians)+pi?  Aren't there 2pi radians in a circle?
That pi gets subtracted again later. It just makes sure that the remainder is mapped into -pi..pi instead of 0..2pi.
EDIT: nevermind.  I had it turned around.
"Should be" isn't "Is" -Jay
Message 2591 of 2,611
(1,561 Views)
Turned around by 360 degrees? 😄
Message 2592 of 2,611
(1,551 Views)
That would have actually worked out just fine. I was looking backwards by pi.
Message 2593 of 2,611
(1,499 Views)
Sometimes the origin story for Rube Goldberg code lies with instructions from the professor:
Quote:
He only uses LabVIEW and apparently gives this assignment to students doing research under him every now and then.
P.S. He instructed me to try implementing this using a stacked sequence structure and local variables
(seen here)
Message 2594 of 2,611
(1,394 Views)
Maybe this is his professor.
Message 2595 of 2,611
(1,272 Views)
Surprisingly 'cute' and organized VI, but so much unnecessary code!
I need to observation - NI Community
Qestit Systems
Certified-LabVIEW-Developer
Message 2596 of 2,611
(1,212 Views)
"...I built a VI to ...", is a code smell when used by beginners 😁.
Message 2597 of 2,611
(1,193 Views)
Well, at least the wiring looks pretty neat. (Yes, done right, the same code functionality could fit on a quarter postcard.)
However, I am very suspicions about the serial communication in general.
Message 2598 of 2,611
(1,121 Views)
If a FOR loop should iterate based on the number of rows in a 2D array, N does not need to be wired, of course.
However, if we don't trust the compiler we better "calculate" the number of rows based on a one element subset of the array size array turned into a spreadsheet string, then parsed as decimal integer. Why not?
(I am wondering how long it took the OP to get this N value output just right! Guessing hours! 😄 )
(seen here)
The following would be equivalent, but since the code is fundamentally incorrect for the given problem, we don't really care.
Message 2599 of 2,611
(847 Views)
As seen here, you can apparently never have enough event structures... (Yes, most inner event cases contain even more event structures!)
I am sure it took days to build that pyramid, then partially solve all lockup by turning off panel locking for all event cases. What a rabbit hole!
Message 2600 of 2,611
(758 Views)
