BreakPoint
Rube Goldberg Code
@Yamaeda wrote:
@altenbach wrote:
Anyone care to explain the possible thought process leading to all that?
Arrays should be handled by references. All code is better with references. I've learned that in that C++ course i took in -95.
I am sure you did not learn to create a new reference and then destroy it once per iteration in a tight loop.
Message 2461 of 2,571
(1,658 Views)
My head is still stuck at the 2 DVRs that operate "inplace" and wire the values straight through.  (Gain[] and Offset[])
Did you ask the OP? What results could a phrenologist observe?
"Should be" isn't "Is" -Jay
Message 2462 of 2,571
(1,612 Views)
@JÞB wrote:
phrenologist
My word of the day 😁.
Message 2463 of 2,571
(1,582 Views)
They are simply needed to access the data for the calculation. Much like an &ref in C++.
Qestit Systems
Certified-LabVIEW-Developer
Message 2464 of 2,571
(1,515 Views)
There are many ways to quarter a 64bit integer, some are simpler than others. (seen here).
(And yes, SGL would be plenty to do a floating point representation of a 16bit integer, but the decimation operation requires DBL later)
Message 2465 of 2,571
(1,455 Views)
I'll take a guess at your question: "Why so convoluted?".
Many people have no interest in learning anything new.   When they need to code something, they won't even bother searching the palettes for something that might work well.  Instead they just start hacking away with whatever limited knowledge is in their heads.
Message 2466 of 2,571
(1,423 Views)
Maybe you need code that takes 2 DBLs and inflates it to 100k (or more?) DBLs with more hot air than the Albuquerque balloon fiesta.
Here's what to do (seen here ) 😄
Message 2467 of 2,571
(1,330 Views)
The accepted solution equivalent of cutting your finger off to prevent a mouse button press.
Message 2468 of 2,571
(1,182 Views)
So, how would you solve it?
Message 2469 of 2,571
(1,157 Views)
I would also like to know.  Using an Abort button to Stop a vi is extremely dangerous.  It is precisely why no deployed apps have an abort button (unless a LabVIEW Developer forgets to rip it off)
I commonly remove the Abort button.  Removing the button also disables "CTRL+." or any hotkey otherwise assigned to Abort VI.  I started doing that shortly after joining these forums because of advice received from reading many threads.  If you have other practices I would be happy to hear your thoughts.
Message 2470 of 2,571
(1,138 Views)
