BreakPoint
Rube Goldberg Code
I like to use "Matrix Size" to get the number of rows or columns in a 2D array
Message 2281 of 2,300
(2,551 Views)
6 pixels too big!
Actually, I hadn't thought of doing that before. I generally ignore the "Matrix" functions. I'm doing that from now on!
Message 2282 of 2,300
(2,541 Views)
@BowenM wrote:
6 pixels too big!
Darren's Weekly Nugget 10/26/2009
GCentral
Message 2283 of 2,300
(2,530 Views)
I'm probably getting way off topic here, but...
In that Nugget, Darren issued the following challenge:
No, it's not a subVI...it's a built-in function.  If it were a subVI you wouldn't be able to wire any arbitrary 2D array to it.  Not to mention subVI call overhead.  And the allocation of an array for the Array Size output.  I welcome somebody to post some benchmark results comparing the two approaches...I think you'll find Matrix Size to be faster, although I will admit that there probably aren't too many use cases that require extremely performant row/column calculations...
"Ha!" I thought to myself.  "Silly 2009 Darren couldn't see into the future and so he had no idea about malliable VIs. I can too wire an arbitrary 2D array into a subVI".  And since nobody accepted his challenge in 2009, here we are.  I was curious and did the test with a malliable VI.
Matrix Size is still noticeably faster.  Interestingly enough, enabling iteration parallelism brought them much closer to identical, even for higher number of iterations.
So, take that past Darren who was unable to see into the future:  You were only a partially right!
Message 2284 of 2,300
(2,518 Views)
@BowenM wrote:
Matrix Size is still noticeably faster...
I think reading the high res timer value inside the for loop may be skewing your results. I reckon it might be taking longer than the matrix size operation.
Troy - CLD "If a hammer is the only tool you have, everything starts to look like a nail." ~ Maslow/Kaplan - Law of the instrument
Message 2285 of 2,300
(2,510 Views)
Oops. I think you're right... I was being lazy, didn't think of the execution time of the relative seconds. I'll have to try again later.
Message 2286 of 2,300
(2,497 Views)
I've been burned a few times by vims...
At some point I wasted 4 hours because an exe wouldn't build anymore. I had to remove 50%, remove the other 50%, iterate, narrowed it down to a few VIs, remove 50% of the VIs, etc.
The simples vim ever (Synchronize Data Flow.vim) was the cause.
"Heavy" vims tend to introduce a noticeable to unworkable delay, especially when they change, or IIRC even when opened and closed.
Message 2287 of 2,300
(2,484 Views)
Haver had similar issues. Also, files that use vims may get broken if the vim is changed and need to be force-recompiled or that the vim is manually reconnected again to force a recompile. Sometimes I also get broken wires to the vim but a runnable VI. And if I try to minimize the code to post a bug report, the problem goes away.
Certified LabVIEW Architect
Message 2288 of 2,300
(2,480 Views)
If I could have seen into the future, you better believe I'd be sitting on a giant pile of Bitcoin right now.
DNatt, NI
Message 2289 of 2,300
(2,443 Views)
wiebe@CARYA wrote:
The array to cluster + unbundle has the advantage of being 'vertically friendly'.
I'd say a Get Matrix Size saves you a couple of blocks.:)
G# - Award winning reference based OOP for LV, for free! ADDQ VIPM Now on GitHub
"Only dead fish swim downstream" - "My life for Kudos!" - "Dumb people repeat old mistakes - smart ones create new ones."
Certified-LabVIEW-Developer
Message 2290 of 2,300
(2,292 Views)
