03-15-2021 08:39 PM - edited 03-15-2021 08:44 PM
@altenbach wrote:
@JÞB wrote:
I would bet a kudos here and wherever AQ responds that , that right there is a default error ring backsaved for previous version;)
Really? There is a more proper error constant in the other case structure to the right. Back-saving would have affected both. I also have never seen a default error constant where the error is TRUE.
Not if only 1 was backsaved. Bear in mind, there is no LabVIEW for Android viewer. But, I'll double down 2 kudos!
03-15-2021 10:38 PM
Yeah, really
Its nearly too obvious for the thi@ thread !
Danm shame though
03-21-2021 01:29 PM
03-21-2021 05:02 PM
I came across this many years ago.
It took me a long time to figure out what it does. It takes a floating point number in the range of 0 - 100 (which represents a duty cycle) and scales it )linearly) to an integer in the range of 0 - 1200. So it's the same as this:
03-22-2021 03:40 AM
@altenbach wrote:
Yes, this is only the tip of the iceberg!
The tip of the Goldberg?
03-24-2021 02:04 PM - edited 03-24-2021 02:08 PM
I have obviously a serious problem trying to fit data to a single exponential. I am sure you can immediately see what I am doing wrong after studying a picture of the context help; 😄
(Similar: My car does not work, please fix! Here's a picture of the glossy sales brochure!)
03-26-2021 02:15 PM
03-26-2021 08:02 PM
I am scratching my head for an hour but I still have that nagging feeling that this code fragment could be simplified.
03-29-2021 10:37 AM
For something so simple I would just use an expression node 😄
03-29-2021 12:53 PM
This seems to act like the "always copy" function because it creates a new buffer allocation. Except for very rare cases, these decisions should be left to the compiler.
