06-14-2018 09:53 AM
@Jacobson-ni wrote:
wiebe@CARYAwiebe@CARAYA wrote:
Not bad, not bad at all. It saves a click to see what's in the other case, to make sure or to find out it's empty!
Just hope you don't lose errors down stream by not handling the case of a for loop executing 0 times.
Same can happen in a case. Use default instead of wiring through, and the error is lost. In a For Loop, a shift register. Exactly the same: if you write bad code, you get bad results.
06-14-2018 12:25 PM - edited 06-14-2018 12:26 PM
wiebe@CARYA wrote:
@BertMcMahan wrote:
While this isn't exactly OVERLY complicated, it's something I shamefully admit to doing when I first started teaching myself LV. I didn't know about Case structures, and needed something to execute or not based on a boolean, so here's my janky boolean solution:
I have not investigated it recently but NI did have a Patent on a 3-D diagram that provided your perspective of the diagram was right, you would be able get a glimpse of more than one case at a single glance.
Ben
06-27-2018 09:22 PM - edited 06-27-2018 09:23 PM
True greater than a boolean? I had to run some test code to find out that it gives the same result as a NOT.
06-28-2018 05:50 AM
And the NOT can of course be implemented as invert on the compound AND.
08-04-2018 02:10 PM
So we have a case structure (boolean selector) where the contents of the two cases are identical, differing only by a boolean diagram constant that we already have. (See here)
I don't think that case structure is needed at all!
08-17-2018 11:02 AM
Rube Goldberg code often looks complicated, so for something a little easier to look at, here's deceptively simple Rube Goldberg code.
(The poster claims 1 year "LabVIEW experience", whatever that means. Maybe in another few years he might stumble across the stop button by accident :o. We just need to be patient! :D)
08-17-2018 12:25 PM - edited 08-17-2018 12:29 PM
Really Christian, haven't you ever seen the Abort Button? 😄
Damnit it's hard to type in a phone when you're screen is covered in coffee because you forgot to swallow before reading a post
08-17-2018 12:31 PM
There's even a button on my computer case that seems to work just fine if I press it long enough. 😄
08-21-2018 06:07 PM
Seen on a l
LabVIEW thread I recently replied to.
Kudos for a link and picture
I know, let's build all of these scalar values into an array then IMITIATLY wire it directly into an index array to get the scalar values back. Look no wire branches.
08-23-2018 02:53 PM
What's the matter?
Is that "X" in the upper right hand corner of the window not a good enough stop button for you? 😛
