09-30-2021 08:48 AM
09-30-2021 10:38 AM
Careful!
The Unflatten From String solution is only the same if there are two (or more) characters in the string!
09-30-2021 10:58 AM
wiebe@CARYA wrote:
Careful!
Yes, but here he is reading exactly 2 bytes from the network, so the size is guaranteed. 😄
10-04-2021 10:47 AM
Converting three bytes into a floating point value (seen here).
I have the nagging feeling that we don't need anything green and much less orange.
10-30-2021 10:56 AM
To a text programmer, this formula node probably looks very reasonable. I have the gut feeling that there are simpler alternatives. 😄 (seen here)
11-02-2021 01:12 PM - edited 11-02-2021 01:20 PM
Sometimes the Rube Goldberg is not in the code, but in the external wiring. (seen here)
Question: "Please share ... connection diagram of how everything is wired up"
Answer: The encoder is connected to Counter 0 while the servo connections are made to the Counter 1. The Encoder has 5 cables and they go into pins 96 (+5V), 86 (DGND), 81 (channel A), 85 (channel B) and 83 (Z index). Servo has 3 cables and they go into pins 96 (+5V), 94 (DGND) and 91 (signal).
I already see the sparks fly!
11-03-2021 02:27 AM
Jesus christ, that cable is completely shredded. How it didn't blow up yet is a real mystery.
11-24-2021 07:39 AM
Lots of lessons to be learned here (please pitch in 😋).
Some highlights (RB, Bugs, and other madness):
11-25-2021 12:48 PM
Can you explain the up to three values for each time point? Are they related?
11-26-2021 03:04 AM
I think there's time, and then 1, 2 or 3 (maybe more?) values. The graphs shows the 1, 2 or 3 values as a function of time. So I think those values are positions, and s(he)'s trying to correlate the positions to 1, 2 or 3 objects that move over time, in one dimension.
But that is my interpretation.
I do see a strong coherence between bad solutions and bad explanations of the problem. 🙄
