BreakPoint
Rube Goldberg Code
Highlighted
I had this one
staring me in the face most of today before I finally realized what it was...
Spoiler
 -joeorbob
Message 2221 of 2,237
(935 Views)
@joeorbob wrote:
I had this one
Spoiler
 -joeorbob
Well...
Sometimes code like that is convenient during testing. If you're not sure the First Call does the job, the Boolean is a quick way to test by switching between "always true" and "first time true".
I'd at least make it a control. Then I can set it to true while running, and it will reset to false next time I load the code. So if I forget to remove it, at least it won't do anything.
Of course it should be removed after testing. But I feel this could be a "left over from testing" instead of "Rube Goldberg".
Message 2222 of 2,237
(913 Views)
Highlighted
I am not going to repeat the entire discussion here, but the collective efforts of a few community members was able to iteratively speed this code up ~30000x (from 5 minute to a few ms) and literally reduce it to the size of a postage stamp. 😄
LabVIEW Champion. It all comes together in GCentral GCentral
What does "Engineering Redefined" mean??
Message 2223 of 2,237
(807 Views)
Highlighted
To add a single point to a chart, we apparently need to (1) take a subset containing one element, then (2) turn it into a 2D array with one element, before (3) feeding it to the chart. Repeat for four other charts. (Seen here).
I can think of something slightly simpler. 😄
Message 2224 of 2,237
(645 Views)
Highlighted
(seen here)
My gut feeling is that this can be slightly simplified, but I cannot find a replacement. Which palette contains a wire?
Message 2225 of 2,237
(526 Views)
Highlighted
@altenbach wrote:
(seen here)
I took the liberty to try and simplify it a bit 😄
Message 2226 of 2,237
(489 Views)
Highlighted
Most are familiar how to flip a boolean, but have you ever tried the double-back-flip-triple-axel-boolean operation?
(seen here)
Message 2227 of 2,237
(319 Views)
Highlighted
(seen here)
I believe it is called a triple lindy.
mcduff
Message 2228 of 2,237
(312 Views)
Highlighted
Ha! You are right! Totally forgot about this one. 🙂
Message 2229 of 2,237
(296 Views)
Highlighted
It took me far too long to realize this was a parody.
Message 2230 of 2,237
(284 Views)
