BreakPoint
Rube Goldberg Code
Highlighted
@BowenM wrote:
I think I've posted this story before, but it is one of my favorites. This reminded me of it
(Of course the hardware team will substitute a 10x faster processor in the next iteration .. BOOM!. 🐵
LabVIEW Champion. It all comes together in GCentral GCentral
What does "Engineering Redefined" mean??
Message 2191 of 2,223
(983 Views)
Highlighted
@BowenM wrote:
@altenbach wrote:
Not really Rube Goldberg code, more a Rube Goldberg concept (seen here).
"If you quickly run out of memory, add a time delay so you run out of memory more slowly. :D"
(That particular code would take 5 days with the suggested delay so we can start the program on Monday and leave for the weekend without ever running out of memory. Problem solved!!!)
A troubled program being blown up in action will hunt me in my sleep.
Only fixing the source will send it into the light 👼.
Message 2192 of 2,223
(938 Views)
Highlighted
Seen here
Haven't seen these in a while, but they are just the tip of the iceberg.
Maybe somebody want to help fix all that code. It has doozies like the following.
Message 2193 of 2,223
(831 Views)
Highlighted
That's almost as embarrassing as some of my Rube-ish attempts at coding early in my career.
Bill
CLD
(Mid-Level minion.)
Message 2194 of 2,223
(801 Views)
There's a saying I read somewhere, though I can't seem to find it now.  Something along the lines of:  "Good code is what you just wrote. Bad code is what your coworker just wrote. Terrible code is what you wrote 6 months ago"
I can't tell you the number of times I've been looking through old code and thought "oh wow. What was I thinking?!"
Message 2195 of 2,223
(750 Views)
Highlighted
Seen here
So we have a 1D array that should have a linear scaling applied.
Some programmers thing that we:
  1. Need to measure the length of the 1D array
  2. Take a subset of that array starting at zero and having the original length.
  3. Create arrays of the same length for two constants.
  4. Divide by one of these arrays and multiple with the other
  5. Subtract the other array
My gut feeling is that this could be simplified! I wonder how much the LabVIEW compiler can strip out from the original. 😄
Message 2196 of 2,223
(680 Views)
Highlighted
The problem is simple: Take any 2D array and interleave empty rows and columns to double the size. (seen here)
There are many ways to do this, Here are two alternatives.
One of them might take less time to write, debug, and verify. 😄
Decisions, decision!
Message 2197 of 2,223
(604 Views)
Highlighted
We talked about Aztec code architecture before, but it seems that some will take it to the next level and implement Mayan Code Architecture:
(seen here)
Yes, I actually visited Tikal in 1980. Quite an adventure!
Message 2198 of 2,223
(451 Views)
Highlighted
(seen here)
But it's OK because he left out more bad code. 🤣
Message 2199 of 2,223
(416 Views)
Highlighted
One would think that having a single 2D array shift register receiving a row would be slightly simpler than 28 (!!) 1D arrays, each receiving a scalar per iteration. ( very small code section seen below)
(seen here).
What hurts the eye (and brain!) even more is all these detours via shorts stretches of dynamic data. Yuk! I am not even trying to figure out what they should do.
Message 2200 of 2,223
(329 Views)
