BreakPoint
Rube Goldberg Code
@cbutcher wrote:
More useful displays might include adding units, or labeling your indicators 'inline' (obviously for display only). (Maybe you can actually get the text representation and then do something?)
Writing to that property is exactly what my Format Numeric Quick Drop plugin does.  And, yes, I put units in the format all the time.  One of my favorite formats is "%#pHz" ('#' ignores 0s after the decimal, 'p' is for SI Notation).  This will show values like "2.4GHz" and "10Hz".  That is a lot easier to read than 2400000000.
GCentral
Message 2101 of 2,571
(10,139 Views)
IIRC, this doesn't work that well for controls though. Some units confuse the input, mixing up the SI Notation and units.
Message 2102 of 2,571
(10,131 Views)
The only time I have ran into problems was with a Scan From String.  But that CAR (425562) was fixed at some point.  I just tested with 2016 and it works fine.  I would have to do some more forum digging to figure out when it was fixed.
EDIT: I just realized what you were referring to.  Like "meters" is shortened to "m", which can be interpreted as "mili".  I will have to play around with that one to see how controls react.  I would guess it would be fine as long as the user did not enter the units.
GCentral
Message 2103 of 2,571
(10,128 Views)
Also have a faint recollection about mft (milli feet) that didn't work...
Not sure what the problem was exactly, but meters being interpreted as 10E-3 sounds familiar.
Units are more or less obsolete (not supported in NXG for sure). They are still natively supported in C++ though. There are use cases...
I especially use them for automatic conversion when using by reference. So I use references to load\store values in an ini file. The value property returns the real value, for instance in meters or kg) regardless the unit. The user sees the values in mm or grams. The real unit doesn't matter, I only use it to automatically convert between n, u, m, -, k, M, G, etc. Very convenient, and no substitute.
Message 2104 of 2,571
(10,108 Views)
My favorite is some flavor of %.2ps to display benchmark timing (100.00ms, 900.00ns, 20.00s, etc.)
Message 2105 of 2,571
(10,098 Views)
Sounds like we need a thread in Breakpoint or a Nugget for this. It is an interesting concept and I think there are a lot of people that could use this information.
Tim
GHSP
Message 2106 of 2,571
(10,092 Views)
Well yes. 😄
Message 2107 of 2,571
(10,082 Views)
Having an electronics background I'm familiar with "mil" (thousandth of an inch) due to working with circuit boards, but this is the first time I've ever heard of "milli feet".  Coming from a country that is metric (hang on, isn't the U.S. officially metric too?) the idea of milli feet is horrifying.Smiley Surprised
Troy - CLD "If a hammer is the only tool you have, everything starts to look like a nail." ~ Maslow/Kaplan - Law of the instrument
Message 2108 of 2,571
(10,055 Views)
I guess a millipede has 1000000 mft. 😄
Message 2109 of 2,571
(10,037 Views)
And,  I took a wrong turn this morning on the way to the office,  Suddenly I'm driving 120....How fast is that?
Spoiler
Maybe I should take a bus I bet C.A. would approve
more like 12,000,000 m" (or 1,000,000 m') It could be 1Mm'
"Should be" isn't "Is" -Jay
Message 2110 of 2,571
(10,007 Views)
