03-28-2018 10:54 AM
03-28-2018 09:47 PM - edited 03-28-2018 09:50 PM
wiebe@CARYA wrote:
@JÞB wrote:
The comparison to constant is not needed since you can use the case to switch on the constant.
Actually, All (that I can think of off the bat) Comparisons to constants feeding a case selector are r-g
Except...
SpoilerComparing floats to -Inf, NaN or +Inf constants!
Actually, there is a legit case for this. You just named three of the five IEE 754 FP exceptions. There might be a reason to do something if these occurred.
Didn't read your spoiler closely enough. I missed what was written immediately above it.
04-02-2018 09:09 AM
Seen in the wild
(unfortunately, in code I need to maintain now):smileysad:
04-02-2018 09:27 AM
And I am guessing that is not a simple dialog. I have done similar for dialogs to pass out what the user configured, but those typically just write the values out when the OK button is pressed.
04-02-2018 09:40 AM - edited 04-02-2018 09:45 AM
It gets worse, there is no means available to the vi where Auto Run is visible or enabled. Therefore, the case cannot execute unless someone is messing with a vi server ref to this vi.
EDIT: "Don't worry Jeff, That autorun feature never worked and we can't figure out why....
There is also a mouse down event on 26 clusters of string (values A-Z) that fires a user event of (string A-Z) handled by the same event case.....to sort a list ......
04-04-2018 04:55 PM - edited 04-04-2018 05:06 PM
So why did nobody else ever think of that??? (seen here) 😮
paraphrasing:
"To avoid memory issues we should not use an outer while loop but use the "continuous run" button instead."
Hmmm.... NO!!!!
04-05-2018 02:29 AM
paraphrasing:
Hmmm.... NO!!!!
Isn't working around a problem better then solving it? That's not what I've heard...
A colleague at my previous job (20 years ago) asked me if I could make a .dll to kill the current process. He had a memory leak, and in stead of asking me to solve it, he figured it was easier to simply restart the application once a day.
There and then I realized this. Everyone can learn how to program. But some people should not be allowed to. At least not without supervision.
04-11-2018 04:49 PM
wiebe@CARYA wrote:
paraphrasing:
Hmmm.... NO!!!!
SpoilerA colleague at my previous job (20 years ago) asked me if I could make a .dll to kill the current process. He had a memory leak, and in stead of asking me to solve it, he figured it was easier to simply restart the application once a day.
Reminds me of this story
04-11-2018 11:23 PM
@BowenM wrote:
wiebe@CARYA wrote:
paraphrasing:
Hmmm.... NO!!!!
Similar to a recent post, where the OP stated he should move to LV 64bit because he has memory leaks...Well, for sure you can delay memory issues, just buy more RAM...
04-12-2018 03:02 AM
@Blokk wrote:
@BowenM wrote:
wiebe@CARYA wrote:
paraphrasing:
Hmmm.... NO!!!!
Merging LabVIEW 32 bit project into LabVIEW 64 bit will it work for all the DLLs and library's ?
In all fairness, OP mentions "memory problems", not memory leaks per s. Although leaks are very likely to be the problem, OP could just needs a lot of memory. Anyway, fixing them by optimizing the code to some degree is a better solution then simply upgrading. But he might have done that already (although very likely he didn't).
