BreakPoint
Rube Goldberg Code
@JÞB wrote:
The comparison to constant is not needed since you can use the case to switch on the constant.
Actually, All (that I can think of off the bat) Comparisons to constants feeding a case selector are r-g
Except...
Spoiler
Comparing floats to -Inf, NaN or +Inf constants!
Message 1971 of 2,571
(10,620 Views)
Except...
Spoiler
Actually, there is a legit case for this.  You just named three of the five IEE 754 FP exceptions.  There might be a reason to do something if these occurred.
Didn't read your spoiler closely enough.  I missed what was written immediately above it.
Bill
CLD
(Mid-Level minion.)
Message 1972 of 2,571
(10,577 Views)
Seen in the wild
(unfortunately, in code I need to maintain now):smileysad:
"Should be" isn't "Is" -Jay
Message 1973 of 2,571
(10,514 Views)
And I am guessing that is not a simple dialog.  I have done similar for dialogs to pass out what the user configured, but those typically just write the values out when the OK button is pressed.
GCentral
Message 1974 of 2,571
(10,506 Views)
It gets worse, there is no means available to the vi where Auto Run is visible or enabled.  Therefore, the case cannot execute unless someone is messing with a vi server ref to this vi.
EDIT:  "Don't worry Jeff, That autorun feature never worked and we can't figure out why....
There is also a mouse down event on 26 clusters of string (values A-Z) that fires a user event of (string A-Z) handled by the same event case.....to sort a list ......
Message 1975 of 2,571
(10,500 Views)
So why did nobody else ever think of that??? (seen here) 😮
paraphrasing:
"To avoid memory issues we should not use an outer while loop but use the "continuous run" button instead."
Hmmm.... NO!!!!
Message 1976 of 2,571
(10,467 Views)
paraphrasing:
Hmmm.... NO!!!!
Isn't working around a problem better then solving it? That's not what I've heard...
Spoiler
A colleague at my previous job (20 years ago) asked me if I could make a .dll to kill the current process. He had a memory leak, and in stead of asking me to solve it, he figured it was easier to simply restart the application once a day.
There and then I realized this. Everyone can learn how to program. But some people should not be allowed to. At least not without supervision.
Message 1977 of 2,571
(10,433 Views)
wiebe@CARYA wrote:
paraphrasing:
Hmmm.... NO!!!!
Spoiler
Reminds me of this story
Message 1978 of 2,571
(10,245 Views)
@BowenM wrote:
wiebe@CARYA wrote:
paraphrasing:
Hmmm.... NO!!!!
Spoiler
Similar to a recent post, where the OP stated he should move to LV 64bit because he has memory leaks...Well, for sure you can delay memory issues, just buy more RAM...
Message 1979 of 2,571
(10,200 Views)
@Blokk wrote:
@BowenM wrote:
wiebe@CARYA wrote:
paraphrasing:
Hmmm.... NO!!!!
Spoiler
Merging LabVIEW 32 bit project into LabVIEW 64 bit will it work for all the DLLs and library's ?
In all fairness, OP mentions "memory problems", not memory leaks per s. Although leaks are very likely to be the problem, OP could just needs a lot of memory. Anyway, fixing them by optimizing the code to some degree is a better solution then simply upgrading. But he might have done that already (although very likely he didn't).
Message 1980 of 2,571
(10,177 Views)
