BreakPoint
Rube Goldberg Code
@Blokk wrote:
From here:
https://forums.ni.com/t5/LabVIEW/Problems-with-Quotient-amp-Remainder-in-FPGA/m-p/3723904/highlight/...
I had to stare at that far longer than I should have to figure out what was going on.
Message 1872 of 2,571
(10,668 Views)
@BowenM wrote:
@Blokk wrote:
From here:
It's not that badSmiley Very Happy. Just replace the two Booleans, two shift register, the AND, the selector and the 7 wires for a "First Call?". So 7 nodes, 7 wires replaced by 1 node and 0 wires? Yes, that's Rube Goldberg Code alright!
Somehow that one pixel jump in the top wire (on the right) bothers me more then in should.
Message 1873 of 2,571
(10,636 Views)
Actually, it looks like you still need the feedback node, because the point is to check the current time against the start time. One option would be to use the FN and select. Another might be to use just the FN and set it to initialize on first call, then wire the current time to the init terminal and the output back to the input.
___________________
Try to take over the world!
Message 1874 of 2,571
(10,632 Views)
Yes, one. The other two are redundant.
But the First Call? is indeed not needed, as it's function is build in the FB.
Message 1875 of 2,571
(10,627 Views)
Let's wait for a period of time, in 10 msec chunks, but the number of times to wait is based on a arithmetic series.
Seen here.
While loop near bottom after VISA Write
Message 1876 of 2,571
(10,526 Views)
@RavensFan wrote:
Is that uninitialized shift register a bug or a feature?
Message 1877 of 2,571
(10,520 Views)
that is the rube goldebergish part 😉
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 1878 of 2,571
(10,516 Views)
Why (just covering myself...)?
That's a very efficient way to wait ~500 ms the first time, and then until the next 10 ms multiple forever after.
It could a bug or a feature. In the last case it's programmed pretty efficiently.
Message 1879 of 2,571
(10,503 Views)
i was just kidding regarding the uninitialized shift register
Message 1880 of 2,571
(10,500 Views)
