BreakPoint
Regular Expressions Board
I got the first portion working by using the following regex:
SEP_OF_ME_IS_A_CONFIG_TABLE\#\#\n(.*) :ab50_34_cdef
followed by the first part of the example you provided.  Still elegant. Thank you.
I know the above expression looks for the data in between both strings, but I also have access to the string that immediately follows the match.
Now onto the 2nd portion.
Message 51 of 150
(10,580 Views)
You have to be careful with wild card s in regular expressions. You can get greedy matches with may result in the wrong match. This is the reason I try to bracket the data for the specific search I am doing. A greedy match can be grabbing LOTS more stuff than you may think.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 52 of 150
(10,576 Views)
Anyone up for validating a regex for me? I'm trying to match any filename that does not begin with a tilde (~) and has a filetype of .xls or .xlsm. Here's the regex I've got so far: ^[^\~].*\.(xls|xlsm)$
It seems to work against most the test vectors I can come up with (+1 for VI Tester!), but I'm not experienced enough with regexes to see any lurking "gotcha".
Here's how I read that regex: Make sure that the first character anchored to the beginning of the string is not a literal tilde, and then match any and all characters up until requiring a literal dot followed by either xls or xlsm anchored to the end of the string.
Message 53 of 150
(10,522 Views)
You can write it slightly more compactly as:
where the question mark signifies 0 or 1 instances of the previous token, which in this case is the letter "m".
Can't see any gotchas in that.
Message 54 of 150
(10,493 Views)
I found this guide really helpful http://www.regular-expressions.info/reference.html
Specifically, the "*? (lazy star)" explanation. It was not covered in the NI documentation.
Message 55 of 150
(10,453 Views)
@jcarmody wrote:
I answered this question:
@emyh wrote:
[...] have: C1-C10
(C1-C10 means there are actually ten cmponents; C1, C2, C3...C10)
I now want to convert the array containing C1-C10 into an array looking like this:
C1
C2
C3
C10
... with this Regexp:
Read the Regexp like:
  • ([A-Z]) find an upper case alpha-character and store it in a backreference
  • ([0-9]+)find one or more digits and store it, too, in a backreference
  • -find a "-"
  • (\1)find what was found in the first backreference.  In this example it will find a "C" at the beginning and search again for a "C"
  • ([0-9]+)find another one or more digits and store it in a backreference
I'm only using one of the backreferences, but the others are so I can expand the node and get at each of them (in order of appearance in the regexp).
Would there be a regEx that could do the following string without a loop?
\t00\t01\t02\t03\t04\t05\t06\t07\t08\t09\t0A\t0B\t0C\t0D\t0E\t0F
Message 56 of 150
(10,381 Views)
Here is the brute force variation which will work for upto 16 numbers and a more generalized variation that uses a loop.
Mark Yedinak
LabVIEW Champion
Message 57 of 150
(10,373 Views)
LOL!!
Sometimes it is simply better to use the basic method and type the whole thing in...
which is:
"\t00\t01\t02\t03\t04\t05\t06\t07\t08\t09\t0A\t0B\t0C\t0D\t0E\t0F"
Thanks for the example.  It may come in handy in the future.
yagattalovethisthread
Message 58 of 150
(10,364 Views)
A forum member posted a request to extract the data value pairs from an input string which looked like the following: { "Address" : "0xC800A8C0", "Channel" : 0, "Descrip" : "DDNS", "Event" : "Update", "SerialID" : "000b3d016ce3", "StartTime" : "2011-12-01 20:04:51", "Status" : "Start", "Type" : "Log" }.
Here was the solution I suggested using regular expressions.
Note: The regular expression could be modified so the quotes were not escaped. I added the '\' (to escape the quote) initially as a "just in case" measure.
Mark Yedinak
LabVIEW Champion
Message 59 of 150
(10,328 Views)
prepping a question concerning two strings:
freqNone\s\s\s\s\s\s\s\s\s\s\s\setsi18_a_28\s\s\s\s\s\s\s\s\setsi23_a_56\s\s\s\s\s\s\s\s\sfcc23_c_50\s\s\s\s\s\s\s\s\s\r\netsi13_a_28\s\s\s\s\s\s\s\s\setsi18_a_56\s\s\s\s\s\s\s\s\sfcc23_c_30\s\s\s\s\s\s\s\s\s\setsi28_c_28\s\s\s\s\s\s\s\s\r\netsi13_a_56\s\s\s\s\s\s\s\s\setsi23_a_28\s\s\s\s\s\s\s\s\sfcc23_c_40\s\s\s\s\s\s\s\s\s\setsi28_c_56\s\s\s\s\s\s\s\s
freqNone\s\s\s\s\s\s\s\s\s\s\s\suk6L_1_56_R5\s\s\s\s\s\s\s\setsi13_1_28_R5\s\s\s\s\s\sfcc18_1_50_R5\s\s\s\s\s\s\r\nfcc6L_1_10_R5\s\s\s\s\s\s\sfcc11_1_30_R5\s\s\s\s\s\s\setsi13_1_56_R5\s\s\s\s\s\sfcc23_1_30_R5\s\s\s\s\s\s\r\nfcc6L_1_30_R5\s\s\s\s\s\s\sfcc11_1_40_R5\s\s\s\s\s\s\setsi13_2_28_R5\s\s\s\s\s\sfcc23_1_40_R5\s\s\s\s\s\s\r\nic6L_1_29p65_R5\s\s\s\s\sfcc11_2_30_R5\s\s\s\s\s\s\siraq15_2_56_R5\s\s\s\s\s\sfcc23_1_50_R5\s\s\s\s\s\s\r\nic6L_1_30_R5\s\s\s\s\s\s\s\sfcc11_2_40_R5\s\s\s\s\s\s\setsi18_2_28_R5\s\s\s\s\s\sfcc23_2_50_R5\s\s\s\s\s\s\r\nitu6L_1_60_R5\s\s\s\s\s\s\sukr11_2_28_R5\s\s\s\s\s\s\setsi18_2_56_R5\s\s\s\s\s\sfcc23_3_40_R5\s\s\s\s\s\s\r\nmain6L_1_29p65_R5\s\s\sesp13_1_28_R5\s\s\s\s\s\s\setsi18_3_28_R5\s\s\s\s\s\sfcc23_3_50_R5\s\s\s\s\s\s\r\nrus6L_1_28_R5\s\s\s\s\s\s\sesp13_1_56_R5\s\s\s\s\s\s\setsi18_3_56_R5\s\s\s\s\s\situ23_2_56_R5\s\s\s\s\s\s
freqNone            etsi18_a_28         etsi23_a_56         fcc23_c_50
etsi13_a_28         etsi18_a_56         fcc23_c_30          etsi28_c_28
etsi13_a_56         etsi23_a_28         fcc23_c_40          etsi28_c_56
freqNone            uk6L_1_56_R5        etsi13_1_28_R5      fcc18_1_50_R5
fcc6L_1_10_R5       fcc11_1_30_R5       etsi13_1_56_R5      fcc23_1_30_R5
fcc6L_1_30_R5       fcc11_1_40_R5       etsi13_2_28_R5      fcc23_1_40_R5
ic6L_1_29p65_R5     fcc11_2_30_R5       iraq15_2_56_R5      fcc23_1_50_R5
ic6L_1_30_R5        fcc11_2_40_R5       etsi18_2_28_R5      fcc23_2_50_R5
itu6L_1_60_R5       ukr11_2_28_R5       etsi18_2_56_R5      fcc23_3_40_R5
main6L_1_29p65_R5   esp13_1_28_R5       etsi18_3_28_R5      fcc23_3_50_R5
rus6L_1_28_R5       esp13_1_56_R5       etsi18_3_56_R5      itu23_2_56_R5
(I gatta go but will be back with the actual question!)
Message 60 of 150
(10,296 Views)
