BreakPoint
Regular Expressions Board
I was just reading through this discussion and would be happy if you could tell me how to write a string code to the regular expression match to extract the time stamp from an sms text message. My string input is the following:
at+cmgr=1\r\r\n+CMGR:\s"REC\sREAD","+447891089303",,"11/02/24,14:29:32+00"\r\nIT:26.102/IB:11.964/OU:0FL:360.98\s\r\n\r\nOK\r\n.
Hammy.
Message 31 of 150
(13,612 Views)
\d\d/\d\d/\d\d,\d\d:\d\d:\d\d
Does this get what you're after?  11/02/24,14:29:32
Jim
Message 32 of 150
(13,606 Views)
Ever have a need to replace large blocks of ASCII hex with the binary equivalents? This code snippet does just that. It actually looks for the string <HEX: xxxx xxxx xxxx xxxx> and replaces that with the binary data. This works over large blocks of text and will work if the data is split between chunks. For example, if you are reading a large file in chunks and converting the data on the fly. It would be trivial to modifiy the delimiter that defines the block to be converted. This is useful if you have a hex dump saved in an ASCII file and you need to convert it.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 33 of 150
(13,585 Views)
Thanks Mark,
Here's a simple regEx to remove all <tags> from a string.
Message 34 of 150
(13,495 Views)
Any suggestions on how I could improve this Scan From String? (or maybe use some other function)
All I need is the two numeric values (doubles).  I do not care about the leading text (as shown)
I was trying to accomplish it by just extracting the numeric values...
-regEx NooB-
Message 35 of 150
(13,458 Views)
-regEx NooB-
Try this:
You may need to play with the regular expression if your numbers can come back without the decimal point. You will also need to convert the strings to numbers.
Mark Yedinak
LabVIEW Champion
Message 36 of 150
(13,448 Views)
Here is a common construct I use to extract numbers from a string.
Message 37 of 150
(13,437 Views)
This one is from jcarmody on this thread
http://forums.ni.com/t5/LabVIEW/Different-fonts-in-string-indicator/td-p/1601458
He helps someone change color on a string indicator using > or < to determine color.
Tim
GHSP
Message 38 of 150
(13,359 Views)
This one is from Ray R on this thread:
http://forums.ni.com/t5/LabVIEW/regular-exp/td-p/1662386
Tim
GHSP
Message 39 of 150
(13,301 Views)
and the improved version from Jim:
Message 40 of 150
(13,285 Views)
