05-17-2019 10:34 AM
Jim I genuinely appreciate your community support. Over the years there are often neat little coding nuggets I find that you've provided. The one I use most often is a modified version of CaseSelect, which I know of another Jim that appreciates it too.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
05-17-2019 10:49 AM
05-17-2019 10:55 AM
05-17-2019 04:00 PM
I still use the original CaseSelect because it works on things without checking to make sure they are a JKI state machine first 🙂 Jim, while you're up on that pedestal I've got a couple ideas for new features to add...
05-18-2019 08:53 AM
@Jacobson-ni wrote:
I get a lot of meeting invitations from our sales team where I am expected to be some technical resource for a customer that I've never worked with before. That's all normal but every so often I'm introduced with some credentials I didn't know I had which can set expectations a bit high. I'm only 5 years out of college and got two NIWeek meeting invitations today where I was introduced as a "veteran embedded system developer" and "one of our senior applications engineers who specializes in IIoT applications".
It reminded me of an introduction I got from one of our sales team ~2 weeks after starting my current job. I was picking up some work previously being handled by another engineer and the customer was told that, "like Matt Pollock he [me] is also a senior embedded supporter" which is quite a standard to meet considering the other Matt has roughly 3x the experience and helped write the CLED exam.
Anyone else have some crazy high expectations set for them going into a new project? Also, any advice for tactfully resetting expectations?
05-18-2019 11:05 AM
I get lucky sometimes... 😄
Thank you, though, and I [think I] see what you did there.
05-20-2019 08:06 AM
There was an old line that went something like...
If you accomplish the impossible too often they will make it part of your job description.
Ben
05-20-2019 08:14 AM
Ben
Which is why a lot of guys, when asked to help with the laundry or ironing purposefully make a mistake (not too obvious) so that expectations are set accordingly.
Not me though. I'm just incompetent.
05-20-2019 08:22 AM
@Intaris wrote:
...Ben
My better-half will NOT allow me to touch her appliances...
I never willingly screwed things up but there was that one time when she away and I decided I was going to make double batch of chocolate chip cookie bars, mixed up baking soda with baking powder..
Before I knew it the batter was crawling out of the pan onto the bottom of the oven.
My neighbor gave me a strange look when he spotted my fanning the back door trying to clear the smoke.
Ben
07-25-2019 07:27 AM
Some turkeys just do not get it!
Going back and forth looking for something that is not there.
Was Ben Franklin clairvoyant when I he suggested that the national bird should be a turkey? Well you tell me.
Ben
