BreakPoint
Programming Trivia Pop Quiz: Be Different!
Unlike the last question, this one should be common knowledge for everybody.
QUESTION: Find a value that will cause the boolean to be TRUE when the code is executed.
Message 1 of 10
(12,151 Views)
This one is too easy
Spoiler
There is not a number that will return TRUE here.Smiley Wink
GCentral
Message 2 of 10
(12,146 Views)
answer:
Spoiler
might this be a trick question?
i know that you cannot guarantee x + (y+z) == (x+y)+z for floating points,
but to compare the same number/bit-representation against each other should never be different.
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 3 of 10
(12,091 Views)
@jwscs wrote:
answer:
Spoiler
Spoiler
Spoiler
If you look at the definition of floating point numbers, there is a case where it SHOULD be different.
That condition is what Christian is trying to teach us about with this trivia question.
Ben
Message 4 of 10
(12,080 Views)
ok found it...
Spoiler
thought about NaN .. but searched for a constant, didn't enter my mind before to just write it in 😉
guess from mathematical standpoint it makes sense, since the value is undefined
links: https://en.wikipedia.org/wiki/IEEE_754#Formats
https://stackoverflow.com/questions/1565164/what-is-the-rationale-for-all-comparisons-returning-fals...
Message 5 of 10
(12,072 Views)
My first guess was either +inf or -inf.  Interestingly enough, this returns false.  I guess you could prove that a double precision float is countably infinite...
Message 6 of 10
(11,880 Views)
@BownM i must disagree with you, since you only have a finite number of bytes for the representation, it follows, that there can only be a finite number of different numbers.
Message 7 of 10
(11,856 Views)
According to IEEE-754, there is exactly one unique bit pattern for +inf and -inf, respectively. However, there is a huge number of different NaNs. (details)
Message 8 of 10
(11,848 Views)
Approximately 18.4*10^18 unique combinations. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 9 of 10
(11,797 Views)
    • input value:NAN
Message 10 of 10
(11,675 Views)
