BreakPoint
Pet Peeves
11.  Long detailed messages giving as replies to the question proposed.  In the end the OP posts a "Thank you, that worked" message and proceeds to mark their thank you message as the solution.
Message 21 of 39
(16,685 Views)
Even worst, searching for a problem then finding a thread where OP has the same exact problem.  Then OP replying "Oh never mind I figured it out".
Message 22 of 39
(16,678 Views)
@Hooovahh wrote:
Made me look twice:
Spoiler
Message 23 of 39
(16,672 Views)
Tim Elsey
Certified LabVIEW Architect
Message 24 of 39
(16,658 Views)
wiebe@CARYA wrote:
8. Attaching images. Insert an image and\or attach a VI. *Sigh
 8.a Attaching/inserting images of code taken with a camera.
Jim
Message 25 of 39
(16,625 Views)
Providing irrelevant details (example)
Q: How can I plot 1st column of excel sheet if I am having total 10 columns??
A: Same as you would having any other number of columns as long as the count is >1!!
Message 26 of 39
(16,630 Views)
Disappointed that @altenbach did not add these to his list.
  1. VIs that are larger than postage stamps. (He did say this, just not using that verbiage.)
  2. VIs that don't contain complex math, numbers, or functions.
mcduff
Message 27 of 39
(16,627 Views)
I'll admit, I'm regularly amazed at the clever uses of the "Complex" palette that he comes up with.
Normal forum post:  "Hi, I need to do this analysis and am having issues"
altenbach:  "Duh, just use this <obscure complex math function I would never have thought of using in 100 years>
Message 28 of 39
(16,461 Views)
When the OP marks the "but did you really check X" post as the solution instead of the post that said to check X.
Message 29 of 39
(16,309 Views)
Or: "thanks, your reply solved my problem.", and then select that post as answer.
Message 30 of 39
(16,301 Views)
