BreakPoint
Next Knight?
P@Anand wrote:
@crossrulz wrote:
P@Anand wrote:Its now time for you to learn LVOOP to fill Ben's place. Smiley Wink
I know enough LVOOP to be dangerous.Smiley Tongue
Ok, I may not be a huge LVOOP person, but neither was Ben.  And I think I have filled in his shoes pretty well.  At least Jeff told me I have.  I'm only half of his post count, but gaining quickly.
I am just wondering at his age what will be the number displayed on your Knight shield  Smiley Indifferent
I exactly know it. It will be 154376 plus a few community postsSmiley Very Happy
Message 31 of 45
(10,428 Views)
@muks
I believe you kept Ben as a factor while doing math 🙂
Message 32 of 45
(10,423 Views)
No its even more complicated and a bit like duck worth Lewis method
Message 33 of 45
(10,419 Views)
I think @Branch_Support-NIC posts is a good life goal.
GCentral
Message 34 of 45
(10,410 Views)
But only 4 kudos!
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 35 of 45
(10,400 Views)
@LV_Pro wrote:
But only 4 kudos!
I think that name was only used before the Kudo system came to being.  Or did the "star" system translate into kudos somehow?  Either that or NI support was really bad back in the day.
GCentral
Message 36 of 45
(10,394 Views)
@crossrulz wrote:
@LV_Pro wrote:
But only 4 kudos!
The last post was made on 6/02/2014.
The id is still active
Message 37 of 45
(10,372 Views)
That will be with cheat mode on"
Wait now that makes sense
Message 38 of 45
(10,361 Views)
Man two day in the lab integrating a solution and the doppler shift is nearly deafening.
Thanks for picking up the slack while I have work to do Tim!Smiley Very Happy
"Should be" isn't "Is" -Jay
Message 39 of 45
(10,300 Views)
No problem.  You'll need to pick up my slack while I'm at NI Week.
GCentral
Message 40 of 45
(10,294 Views)
