06-25-2014 12:25 PM
P@Anand wrote:
@crossrulz wrote:
P@Anand wrote:Its now time for you to learn LVOOP to fill Ben's place.I know enough LVOOP to be dangerous.
Ok, I may not be a huge LVOOP person, but neither was Ben. And I think I have filled in his shoes pretty well. At least Jeff told me I have. I'm only half of his post count, but gaining quickly.
I am just wondering at his age what will be the number displayed on your Knight shield
I exactly know it. It will be 154376 plus a few community posts
06-25-2014 12:32 PM
@muks
I believe you kept Ben as a factor while doing math 🙂
06-25-2014 12:37 PM
No its even more complicated and a bit like duck worth Lewis method
06-25-2014 01:14 PM
I think @Branch_Support-NIC posts is a good life goal.
06-25-2014 01:51 PM
But only 4 kudos!
06-25-2014 02:03 PM
@LV_Pro wrote:
But only 4 kudos!
I think that name was only used before the Kudo system came to being. Or did the "star" system translate into kudos somehow? Either that or NI support was really bad back in the day.
06-26-2014 12:43 AM
@crossrulz wrote:
@LV_Pro wrote:
But only 4 kudos!
The last post was made on 6/02/2014.
The id is still active
06-26-2014 02:16 AM - edited 06-26-2014 02:36 AM
That will be with cheat mode on"
Wait now that makes sense
07-17-2014 03:52 PM
Man two day in the lab integrating a solution and the doppler shift is nearly deafening.
Thanks for picking up the slack while I have work to do Tim!
07-17-2014 06:25 PM
No problem. You'll need to pick up my slack while I'm at NI Week.
