09-01-2017 08:41 AM
Continued from the August 2017 bug thread
The posting rules are as always:
09-08-2017 07:56 AM
CAR 664939
Ben
09-18-2017 11:37 AM
Changing a linked input tunnel into an output makes a VI unsaveable due to a "LabVIEW Save error code 5: BD Heap" error.
09-18-2017 05:25 PM
Use of angle brackets in the Build Specification Description for and FPGA build causes error when building because the description is being interpreted as an HTML tag. Angle brackets should be disallowed or escaped internally.
09-18-2017 05:42 PM
Do you have a link to a thread where this is discussed?
09-18-2017 06:04 PM
No, I started here and thought someone could create a discussion thread if needed.
09-19-2017 11:04 AM
No. Read the rules in the first message of the thread.
Start the discussion elsewhere. No discussion in this thread. Just a message here to link to the discussion thread.
09-28-2017 05:45 PM
It was filed before the thread started if that matters at all.
10-01-2017 02:27 AM
