10-31-2018 11:38 PM
Continued from the October 2018 bug thread
The posting rules are as always:
11-02-2018 11:19 AM
11-02-2018 01:50 PM
@altenbach wrote:
All buttons in the help generate script errors if the help is opened from within LabVIEW. (No CAR yet).
CAR now issued: CAR #718419
11-13-2018 01:06 AM
Not so much a bug, but an error in the help text:
The Get Image invoke node (used to grab the image of a graph for example) is incorrectly stated as "Available in Real-time operating system" in LabVIEW 2018 (unlike in other versions), which is not the case (well, it might be available on some targets which support having a GUI, like cRIO-9030 for example, but on most systems the node will return an invalid reference error when running as an application on RT targets):
11-13-2018 07:57 AM
@Mads, please link to the thread where this bug (potential bug?) is being discussed. This thread is just intended to aggregate other discussions taking place. That being said, I too suspect that on Linux RT with the embedded UI enabled that this will function properly.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
12-01-2018 12:35 AM
Continued here. This thread is now closed.
12-04-2018 08:06 PM - edited 12-04-2018 08:07 PM
LabVIEW stores information from MyNI.com for the Default data to import into the Application Builder rather than the Data from a Volume Licence Server when a License is checked out from the Volume License Server.
I understand a CAR is forthcoming. Not a BIG problem until you start deploying a HAL MAL with ppls. Those builds should have the right (C) info 😉
