BreakPoint
Monthly Bugs, March 2012
March is here!
Continued from the February 2012 bugs thread
 The posting rules are as always:
  • Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  • One post/bug!
  • One bug/post!
  • No discussion of bugs. All discussions of a bug must take place in the original linked thread.
Message 1 of 11
(10,733 Views)
Error in the documentation of the Measures of Mean.vi
CAR#341627
Message 2 of 11
(10,710 Views)
BUG: While remote debugging shows "#0" at array lines, but is not empty error:
http://forums.ni.com/t5/LabVIEW/BUG-while-remote-debugging-shows-0/td-p/1902533  (Link)
Eugen Wiebe
Bernstein AG
CLAD - Certified LabView Associate Developer
Message 3 of 11
(10,703 Views)
Ewiebe,
Please wait a bit before posting into this thread.  Allow the thread where you reported the problem to develop a bit.  Let somebody confirm it is a bug.
Right now you might think you have a bug, but it might be a different problem, even user error.
Let's confirm what you have found is a bug before you list it in this thread.  If a blue NI member posts in that thread with a CAR#, then I would safely say you have found a bug.  Until then, it is just speculation.
Message 4 of 11
(10,694 Views)
Possible to change the color of an object even after it has been locked on the front panel.  (Since at least LV 7.1)
CAR #342471
Message 5 of 11
(10,669 Views)
BUG with simple while loops in LV2011 (caused by not used code)
Link
Eugen Wiebe
Bernstein AG
Message 6 of 11
(10,643 Views)
Message 7 of 11
(10,605 Views)
3D bar graph (Plot helper.vi) used with 2D Y-Z plane view and timestamp doesn't scale Y-axis correctly.
CAR#344934
Message 8 of 11
(10,556 Views)
BUG with tooltip on .NET Assembly.
Link
Eugen Wiebe
Bernstein AG
Message 9 of 11
(10,509 Views)
EWiebe,
Please allow a discussion on your bug to occur for a bit before you post it to the monthly bugs list.  Just because you think it is a bug, doesn't mean it is.  Allow some other people time to discuss it in the original thread and concur with you.  Better yet, wait until an NI employee posts a message that they agree and identify it with a CAR#.
I'm not so sure what you found is even a bug without LabVIEW.  It might be a problem with that particular .NET assembly isn't identifying itself properly.
That is the kind of thing that can be discussed in the original thread before rushing to judgement you have a bug and posting it here.
Message 10 of 11
(10,499 Views)
