BreakPoint
Monthly Bugs, December 2008
monitoring the issue of saving for a previous version may want to track CAR #44420, which is more recent than CAR #40808
discussions here
Message 11 of 35
(8,181 Views)
Jim Kring wrote:
Specifying multiple file types (by extension) for File Dialog fails in Mac OS X
http://forums.ni.com/ni/board/message?board.id=170&message.id=372107
CAR # 818352
Status: Fix planned for next major LabVIEW release (post 8.6 ==> 8.7 or 9.0?)
Correction: this is actually CAR # 111447
Message 12 of 35
(8,169 Views)
CAR: 135687
discussions here
Message 13 of 35
(8,147 Views)
If you use shift while editing a project item (folder) and an arrow key, the edit is ended.
See here
Ton
My LabVIEW Ideas
Message 14 of 35
(8,136 Views)
In LabVIEW 8.6, the contingency table vi manual states that it is a 1-sided test. Output suggests that it is a 2-sided Chi-square without Yates' correction.
R&D (# 135926)
Message 15 of 35
(8,104 Views)
See here.
Ton
My LabVIEW Ideas
Message 16 of 35
(8,081 Views)
The Copy primitive doesn't copy directories consistently.  The copied files go into different destinations depending on whether the destination folder exists or not.
See here.
Message 17 of 35
(8,072 Views)
When doing an "array max & min" on an array that only contains NaN, the max and min are returned as zero, They should probably be NaN instead.
(details)
Message Edited by altenbach on 12-12-2008 03:14 PM
Message 18 of 35
(8,017 Views)
 The help for "array min+max" is partially incomplete and wrong
Incomplete: index = -1 output for invalid inputs (emtpy array, all NaN) is not documented.
wrong: The link to array comparison does not apply to this function at all..
 (See this discussion)
Message 19 of 35
(8,004 Views)
Get Volume Info.vi causes LV RT crash on PXI-8106 Controller (LabVIEW 8.6)
CAR 125607
Message 20 of 35
(7,979 Views)
