BreakPoint
LabVIEW 8.6
If you have upgraded to LV 8.6 what are some of the things that you like about it. Did you have any problems upgrading. Did upgrading solve any previuos problems that you were having. I always upgrade to the latest version (very slowly) on one PC at a time.
I was a beta tester for 8.6 and here are some of the things that I like about it.
Changing properties of multiple objects
Higher performance with Multicore processing
Mathscript enhancements
Breakpoint manager
Quick drop (although tst (I think it was him) version is somewhat better implemented. i found this feature not to be to much different then the search function
Automated case structure tunnel linking. I have been using the tunnel wiring wizard that I got from LAVA and it works great, I am just glad that NI is finally ketching up.
SMALLER VI'S ON DISK
The one "KEY " that I did not care to much for is the block diagram cleanup tool. Every VI that I had laid out very nicely and used the clean up tool on was all messed up when it was done. it worked good for small VI's but for larger ones it was not that great.
What are some of the things that you liked or disliked.
Joe.
"NOTHING IS EVER EASY"
Message 1 of 13
(10,462 Views)
I agree, although I have been using it much more than I used QD, and I also didn't see the recent versions of QD, so I can't say for certain.
The main problem with my version is its maintainability. NI's version gets the list of functions for free and I have to store it somewhere.
The better things in my version (IMO) is that the sort order is more natural, that the actual selection is done in the listbox and that it uses a preference algorithm (albeit a primitive one) to make the sorting even better.
I'm probably going to be using 8.6 regularly, so I'll try to give NI's version a fair try.
___________________
Try to take over the world!
Message 2 of 13
(10,457 Views)
I love the quick drop, but I never found the tool you mentioned until after I had tried it out in 8.6, so maybe my take on it would be different had I already been using a similar tool.
I really like the cleanup tool in a few cases. For larger VI's which I already had laid out nicely, it basically mutilated them. For some reason, loops which were placed one over the other (I always put Producer on top, Consumer on bottom for instance) always get switched around. VIs which were less than one screen size suddenly spanned 3 or more screens. Wires generally ended up with more bends, and more wires / objects were overlapping.
On the other hand, when making 'quick fix' sub-VIs or making small applications, it was very handy. Use the quick drop (or the aforementioned alternate) to quickly place code and wire it basically willy-nilly, then hit ctrl-u and have a functional VI which is put together relatively well. Granted, I never had a terrible time keeping small VIs readable while constructing them quickly, this is still a handy time-saver.
I haven't really looked at the changes to VI size on disk, but if it's a noticeable improvement, I'd very much appreciate it.
My two cents.
Message Edited by corys on 08-06-2008 11:59 AM
-Cory
Message 3 of 13
(10,455 Views)
Another thing that I just noticed on the upgrade page is the platform DVD download. 7.2GB for DVD 1 and 652MB for DVD 2. This is good if you want to upgrade to a new dual layer DVD. I do not have that, so I wish they would have spanned it better. ie put more on the second DVD that way both of them could have been the normal 4.7 GB DVD's
I have looked the VI file size and it is about half of what it used to be in some cases even more. Very noticeable
Joe.
Message 4 of 13
(10,451 Views)
I think the video on the Quick Drop page adequately demonstrates the potential difference in coding speed you'll experience when using Quick Drop as opposed to the palettes (or palette search).
-D
Message 5 of 13
(10,428 Views)
Aye, I found the quick drop to be very quick, particularly with the ability to create shortcuts to particular items (not familiar with the aforementioned tool available previously, and if this feature was available or not). Some of my more commonly used functions could be placed on the diagram faster than even the time it takes to wait for the palettes to open after placing the cursor over them.
-Cory
Message 6 of 13
(10,426 Views)
corys wrote:
...not familiar with the aforementioned tool available previously, and if this feature was available or not
It is. You can find it here.
While I wouldn't push people to use it regularly, because it was never finalized and has some issues, I do suggest you try it for a while. It has some features which I feel are implemented better than in QD and if others like them better as well and make enough noise, NI will hopefully invest the time in implementing them. Also, if there's anyone not upgrading to 8.6, this tool works with any version from 7.0 and above. I've been using it in 7.0 for months.
___________________
Message 7 of 13
(10,396 Views)
Thanks for the link, tst, I'll have to try it out.
-Cory
Message 8 of 13
(10,377 Views)
Yes, diagram cleanup totally destroys my carefully crafted layout on larger VIs.  In some cases it also leaves too much space inside structures (loops, case, etc.), causing my diagram to explode in size.  I've tried changing the parameters.  It has some effect, but then other things are grouped too close.  I understand (from NI Week) that they are working on a version of cleanup that will operate on a selection of objects.  Another thing that would be nice (as alluded to by another reply to this thread) would be some way to force certain objects (producer/consumer loops, etc.) to retain their present position.  Yet another thing I would find useful is a 'continue development' setting that would spread things out considerably, allowing me to continue working on the VI.  This would let me easily insert objects into the diagram.
 - les
Message 9 of 13
(10,113 Views)
Something along these lines has existed for a long time. If you hold Ctrl and then hold down the mouse button and drag it expands the diagram. If you're not using the auto tool, you probably have to be in wiring mode to do this.
___________________
Message 10 of 13
(10,084 Views)
