BreakPoint
How much is a CLD employee worth?
@LV_Pro wrote:
That having been said, taking, and passing the exams does provide a level of affirmation, if only to one's self, of a skill level. And in these economic times having it on a resume/CV doesn't hurt! Smiley Wink
I think that going through the certification process is also a very good learning tool. I know I thought I was a very competent LV developer before I started the certification process. After going through the process I improved my skills dramatically and simply getting certified help to raise my level of programming.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 11 of 14
(5,501 Views)
What's a CLD employee worth?
Well there's several thousand for each kidney, probably more for a healthy heart........
Seriously, I think it's all been said already.  You can't pin a salary without knowing
1) What the person does
2) How good they are (CLD does NOT accurately qualify someone's skill level)
3) What other qualifications they might have
4) Where they are working
5) How driven they are
As  Ben said, doing a job you like is half the salary already.  I had a short-term job last year and was extremely unhappy (Crappy management, bad products, no committment to long-term quality goals) and I wouldn't have stayed if they doubled my salary.  I just can't work in that kind of place.
On the other hand, if you go for a job interview and ask for too little (Especially based on your qualifications - I have a PhD so that places me in a certain bracket regarding salary) then this is often seen as an admission of weakness.  Knowing your approximate worth is important when interviewing.  When already in a job it's more important to know the cost of replacing you with someone equivalent.  If you have a rare skill set and are highly integrated into the business you can ask for more from your boss than if you're a regular run-of-the mill electrical engineer (No disrespect).
The friend of a friend is doing not so great on 37000 Euro in "Europe" if the "Europe" is Germany but he's doing pretty well if "Europe" is Romania for example.
Shane
Message 12 of 14
(5,452 Views)
@Intaris wrote:
[...] if you're a regular run-of-the mill electrical engineer (No disrespect).
You can't spell "GEEK" without "EE".
Jim
Message 13 of 14
(5,441 Views)
Its Certified NI Test stand Architect.....Smiley Tongue
Message 14 of 14
(5,317 Views)
