BreakPoint
Half Broken Wire
Today while i was programming i came across a very funny bug. the wire connecting two nodes was half brken and half ok
Does it mean data is getting corrupted in betweenSmiley Wink
see attached VI
right click and clean up wire and everything will be ok
Tushar Jambhekar
tushar@jambhekar.com
Jambhekar Automation Solutions
LabVIEW Consultancy, LabVIEW Training
Rent a LabVIEW Developer, My Blog
(8,511 Views)
Hi Tushar,
it's not a bug. There is one normal wire and a broken rest. If you delete the broken rest, then your vi is ok.
Mike
(8,508 Views)
I don't know if I want to call it a funny bug or a disturbing bug but back in about LV 6.0 there was a bug that involved shift registers and affected AE code constructs. It manifest itself as a wire coming from nowhere, not bieing broken and the VI would run!
The data flow side of  me was doing one of those Star Trek (original series) Norman (Smart android on Mudd's Planet)
"But if you are a liar and you say you are a liar then you are ..."
 brain over-load things.
Ben
(8,493 Views)
Ben's signature: "But if you are a liar and you say you are a liar then you are ..." ...a part time liar!!!!!
- tbob
Inventor of the WORM Global
(8,476 Views)
a politician!
(8,456 Views)
