01-08-2013 07:33 PM
I just tracked down a subtle bug in my code -- this syntax was the culprit:
That's all!
Just sharing a silly bug that cost about a half-hour, intentionally starting a new thread to protest the megathreads that now dominate Breakpoint
01-08-2013 07:55 PM
I am sure I would have found it in 28 minutes. 😄
01-09-2013 07:23 AM
As they say in Texas: "If it was a snake it would have bit ya'.".
01-09-2013 09:45 AM
Been there, done that. 99% of the time, it is something really stupid like that.
01-09-2013 11:57 AM
And the other 1% it's something really, REALLY stupid.
01-10-2013 04:42 AM
Do you think it'd be worth as posting as an idea?
01-10-2013 06:22 AM
Go ahead and post it. It's an interesting idea. If it can be pulled off, I think it would help readability a lot.
01-10-2013 06:34 AM
I'm sorry, but this is what I thought of when I saw your image:
01-10-2013 06:38 AM
It's a cool idea, but one problem with it is that it can only refer to the indices of the primitive itself (i.e. if someone wires a value into one of the inputs and that value is not a constant, then there's no way of knowing what the index in the array would be). I would suggest a modification - if a constant is wired into the primitive (or no value at all), then the primitive shows the indices until the next value wired into an input. Otherwise, it shows the same square which was there until now. I would show that as a demo image in the idea. I would also add an expection where if the index value is large and won't fit into the primitive, the output would show a square instead.
01-10-2013 08:01 AM
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Build-Index-array-element-index-tip/idi-p/987680
