BreakPoint
A call for modern CPU benchmarks
OK, I changed the download to a shared folder on google drive. That should satisfy the https requirement 😄
Message 11 of 37
(7,417 Views)
So for fun I added a few more columns (e.g. max turbo frequency and TDP) and added two derived columns:
  • S/GHz: Serial single core performance normalized to the boost clock frequency. A better CPU architecture will give a higher score. This assumes that the serialized speed runs at max boost. Once all cores run in parallel, the clock might be reduced for thermal reasons.
  • P/TDP: Parallel Spectra/seconds normalized to TDP. Higher is more efficient.
Message 12 of 37
(7,411 Views)
Here's some more results 🙂
Craig H. | CLA CTA CLED | Applications Engineer | NI Employee 2012-2023
Message 13 of 37
(7,402 Views)
@altenbach wrote:
Not sure what you need. What kind of error are you getting with the current link?
No error, it just wouldn't download. No message about it being blocked either, opening the link manually just closes the tab.
The google drive link worked tho, thanks.
Message 14 of 37
(7,386 Views)
Wow, the 3970X single-handedly (or is that 32 core-ly) dethroned the leader and landed in first place with room to spare!
Of course at $3k+ for the CPU alone, we don't expect anything less. 😄
Message 15 of 37
(7,364 Views)
Xeon E-2286G @ 4GHz, while performing a local ISE FPGA compile (1 Core pegged to 100% already).
Message 16 of 37
(7,230 Views)
It may be unrelated, but I had to install LV 2020 runtime for the benchmark and since them my LVCompare (LV 2015 SP1) won't work...... Anyone had similar experiences?
Message 17 of 37
(7,204 Views)
LVCompare.exe is in Shared (C:\Program Files\National Instruments\Shared\LabVIEW Compare), so it probably got updated beyond compatibility...
Message 18 of 37
(7,201 Views)
But surely the LV 2020 runtime doesn't touch LVCompare....? That is an IDE thing, not run-time, right?
Sorry, I don't mean to hijack the thread.
Message 19 of 37
(7,185 Views)
That does make sense... Does the exe work (though the command line)?
Indeed, maybe start a new thread...
Message 20 of 37
(7,150 Views)
