Bloomy Energy Systems
Reply
Highlighted
Mixed Signal Battery Test System
Overview
Bloomy Energy Systems introduces the Mixed Signal Battery Test System in an automated test platform designed to meet today's advanced battery test requirements. The platform is ideal for testing a range of battery cells and packs, and can be used in applications such as research and design, quality control, and end-of-line manufacturing. Its distributed architecture provides a scalable solution with configurable system components to accommodate specific application needs.
Features
  • Battery comunication protocols including CAN, I2C, SMBus
  • Constant current, voltage, and power control
  • Standard and custom charge and discharge profiles
  • Load profile capture and playback
  • Independent channel and parallel channel configurations
  • Flexible hardware configurations: channel count, power, auxiliary IO
  • Custom hardware fixtures and cabling for battery interfacing
  • Industry-leading measurement and control hardware
Benefits
  • Distributed system architecture for easy system expansion
  • Customizable software for user-defined monitoring, tests, alarms, and profiles
  • Wide range of standard test, charge, and discharge functionality
  • Reliable and easy to maintain
Message 1 of 1
(4,174 Views)
Reply
