12-01-2010 01:23 AM
Hi Jimmy,
I couldn't reproduce your problem as I haven't cDAQ at my hand. I will try to find one and go back to you soon.
ZJ Gu
12-01-2010 08:21 AM
Hi Z,
I confirm that the cDAQ module isn't seen by the program Biosignal Logger. I have a cDAQ-9178 with a 9205 module and the only device available as an option is "Dev4 (NI ELVIS II)", a device I don't have.
Salutations,
Michel Goyette
12-01-2010 08:36 AM
Hi again,
After checking the source it became visible that the problem here come's from the "subGetProductCategory" vi calling "nilvaiu.dll" for the product category of all modules (which are detected correctly...my three modules and the cDAQ itself are listed). However, the values return for the product category are all the same (14659) which isn't part in the 3 choices ("M Series DAQ", "NI Elvis", and "Vernier DAQ").
Hope this helps,
Michel
12-01-2010 08:56 AM
Ok, got it to work.
Edit the "SubFindDAQmxDevices.vi". In the "False" case add the device "cDAQ" with a value of 14659. From that point your modules should be seen in the program and then you can choose the right one and select the channels you wish to log.
Good luck,
Michel
12-01-2010 06:52 PM
Hi Michel and Hi ZJ,
Good News, I got the biosignal logger to work with my cDAQ-9178. I did as Michel suggested; however, I am not having any luck, now that I am transporting these .tdms files from the online biosignal logger to the ECG extractor although, the ECG extractor works on all the MIT-BIH archive files. Maybe it is the way I set up the logger in creating these files. Please advise.
Jimmy
12-01-2010 07:30 PM
Hi Jimmy,
Could you please attach the tdms file here for me to have a look?
Hi Michael,
Thanks for your help! That's right! We will try to add more modules/cards type in next update.
ZJ Gu
12-02-2010 02:01 PM
Hi ZJ,
I am enclosing a sanpshot of the ECG Feature Extraction Window and the log.tdms file created from running the Online Biosignal Noise Reduction Data Logger. The ECG Feature extractor does not pickup the P and T waves. I tried adjusting the wavelet Peak Detection Parameters and also the QRS/P/T wave refinement adjustments; unfortunately, didn't make a difference. Please advise.
Jimmy
12-06-2010 12:37 AM
Hi Jimmy,
Sorry for the late reply. I think the issue is coming from the tdms channel settings. ECG signal is usually in mV level however the tdms you provided is in V and the value in your tdms is -1~ 1. I think the correct unit for your tdms is mV. If I change the unit to mV, ECG Feature Extractor works:
You could use the functions under TDMS palette to change the channel unit.
Thanks!
ZJ Gu
