Bay Area LabVIEW User Group
how to convert a video into a bitstream
i am currently working on a project on video transmission using digital modulation techniques in LabVIEW.
anyone provide me with a method or a vi to convert the video to bitstream so that it could be fed to the modulator such as PSK or CPFSK.
(7,000 Views)
Hi!
Did you find some method, I'm working in something similar that you did.
(6,026 Views)
I am programing vision on FPGA.
On the FPGA we convert every image to bitstream
Would that help?
Amit Shachaf
(6,015 Views)
yes, i'm not working on FPGA but the block diagram could help to get an idea
(6,010 Views)
I attach a function that converts 2D Image image to Pixelbus
I use this function to simulate FPGA processing.
I translate image on the PC into Pixelbus steam and test my algorithms on the PC.
Then after I simulate I convert the image back.
You need to use 2D Image to PixelBus x1.vi
I think this should do what you need.
You should set the Insert delay to 0. It doesn't mean anything in your case on a PC.
This is to simulate different loop timing on FPGA.
Hope that helps
Amit Shachaf
(6,000 Views)
I would like to suggest that you remove the Insert Delay from the diagram. You don't need it.
1. DV = Data Valid = True in simulation
2. EOL = End of line
3. EOI = End of Image
Amit Shachaf
(5,996 Views)
