BPS Support
BPS v5.5 Release Notes
BPS v5.5 Updates:
1. Added support for ATCA-3671
2. Added beta 10GbE MAC support with example design
3. Bug fixes and improvements
4. Added default license path check to startup.m script
Known Bugs:
1. Vivado does not set clock frequencies correctly during IP Instantation in BD for Aurora core (Windows bug only).
  • Property is read only so user can not change the incorrect setting. Its recommended to use Linux tools instead if using Xilinx's Aurora core.
(2,052 Views)
hi
I have been working with minibeecube for a year and now
i am moving to megabeecube. working with these platforms lacks the adequate support.
I am going to control the FMC112, how can i control the specs like LO-frequecny and other features using matlab. for example if i wanted to use minibeecube i use
fmc_cmd = sprintf('fmc111_set_lo_freq TX AB %0d', tx_lo_freq);
b4d_send_command(mBEE_ip, 'A', fmc_cmd);
how can I command the FMC112? what are the command list. if you provide me the command list and information about it i am going to prepare a set of functions to control the megabeecube and provide it to you too.
the other problem is that there is XPS_lib which is protected and we are not able to understand the functionality of them.can you provide us a document on it or let us open those functions to see how they command.
(1,042 Views)
I have tried the :
________________________________________________________________________________________
function cmdout = rf_bandwidth(remote, conf, card, direction, rf_bw_hz)
% Function: Set RF Bandwidth with remote account, configuration file, card
% ID (Top/Buttom), signal direction (tx or rx) and RF bandwith (Hz)
% Input Parameters:
% Remote -- root@192.168.0.233 (root@NanoBEE IP Address)
% Conf   -- A configuration file name, e.g. 'example.conf'.
% card   -- RF transcever card ID: 0 (buttom FMC112 card), 1 (Top FMC112 card)
% direction -- signal direction: 'tx' or 'rx'
% rf_bw_hz  -- a string of RF bandwidth, e.g. '30000000' represents 30 MHz.
% Output:
% cmdout: output lines/return from fmc112ctl command.
% Usage examples:
%  Set TX RF bandwidth to 30 MHz on bottom FMC112 card with 'example.conf' configuration file
%  under the current working directory in MATLAB.
%  rf_bandwidth('root@192.168.0.233','example.conf','0', 'tx', num2str(30000000))
sendScpCommand(remote, conf, '/dev/shm/.conf');
cmd = ['rf_bandwidth --file=/dev/shm/.conf --card=' card ' --' direction  '=' rf_bw_hz];
cmdout = fmc112ctl(remote, cmd);
but it says the sendScpCommand is not defined, it seems i dont have the source code for it,
(1,032 Views)
