04-21-2026 06:05 AM - edited 04-21-2026 06:08 AM
I set up a fresh LabView installation on a fresh computer. When I try to create a new XNET session from the project view, I get: "Some components required for editing are missing. Please contact National Instruments for more information".
I already used the "REPAIR" function in the NI Package Manager and let it repair NI-XNET and all of the recommended sub-components. But to no avail.
04-21-2026 08:00 AM
What is the version of LabVIEW you are trying to use? The XNet version does need to be compatible and they are for several versions but there is a compatibility table.
Here is an old table, and here is a more updated one.
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
04-22-2026 12:12 AM - edited 04-22-2026 12:13 AM
I'm running the 2026 Q1 version of Labview 64bit, which is listed as compatible on the second website you provided.
I also have Labview 2019 installed for testing purposes, but this shouldn't be a problem I hope?
04-22-2026 04:47 AM
I uninstalled all packages <= 2020 and also installed LabView 2026 Q1 32bit but still the same error.
04-23-2026 07:43 AM
Correct, this shouldn't be an issue. I have multiple versions of LabVIEW installed. Sorry I can't help more, it sure seems like it is an XNet install issue of some kind.
04-27-2026 02:35 AM - edited 04-27-2026 02:40 AM
Thanks, Hoovah. Looks like it's a software bug known to NI. I found this:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA0VU000000C4W50AK&%3Bl=en-US&l=de-DE
So you can normally use the XNET VIs, but not the wizard.
I installed everything on another PC exactly 1:1 as on the problematic computer and it works just fine.
