ni-can w/ labview 64-bit
Can I use ni-can with labview 2012 64-bit?
I've installed ni-can 2.7.4f0, but during the installation I saw support options for 32-bit labview versions, but none for 64-bit versions. After the install when loading a .vi it can load ncWriteNet.vi. I've looked on a 32-bit installation and that file is in the labview install directory. I tried copying the files manually, but that just leads to other dll dependencies.
thanks,
Paul
(5,837 Views)
Hi Paul,
Almost definitely not.  I think the main landing page for NI-CAN 2.7.4 is pretty clear that you will need to use 32 bit LabVIEW.
Check it out for yourself: NI-CAN 2.7.4 Driver Page.  Look under the "Supported Development Environments".  Also, is there a problem using 32 bit LabVIEW?
NukeB | CLD
(5,826 Views)
