05-14-2006 11:16 PM
05-15-2006 09:45 AM
Hi developer,
because both devices uses different drivers and APIs, you have to detect which device is installed before you can start the communication. If you know which device is installed you can call the code for the device.
For NI CAN devices there is the "ncgethardware" to find which device is installed. For Vector there should be a similar function. For Vector driver Support call Vector directly.
DirkW
