Automotive and Embedded Networks
XNet Remote Ports Accessed Locally
Maybe I'm getting my NI technologies mixed up, but was there a way to access a remote XNet port as if the port was connected locally?  Allowing a developer to make sessions on this remote port using the normal functions?  For instance if you launch the Bus Monitor it will ask about local or remote port.  From there you can enter an IP address, and port, then talk to.  Is there a way to do this in LabVIEW?
I wrote an application that works well locally with USB XNet hardware.  But I also have XNet devices on remote targets and using them would be nice.  The code that runs in Windows could run on that remote target but with major work to support it.  If I could just talk to that hardware as if it were locally connected I could make it work with little effort.
Message 1 of 1
(162 Views)
