01-21-2011 02:34 AM
I'm working with NI-XNET 1.1.1, and a PXI-8513 CAN Card.
I'm using dbc databases created with CANdb Editor.
In these databases, there are Periodic frames, event frames, and frames set as P+E (mixed).
Using the XNET Database Editor, there is no choice for this kind of mixed frames.
I've tried to create 2 different frames with different names but with the same ID, one set as Event and the other set as Cyclic.
This method seems to work, and permits to have a cyclic frame sent with sometimes an interleaved frame.
But the problem with that method is that I need to modify the .dbc databases to take into account the frames with P+E settings.
Those dbc are given to me from automotive customers, and I should not modify them.
Is there an other way to handle those mixed frames? Is there something planned to handle the P+E settings with NI-XNET?
Olivier L. | Certified LabVIEW Developer
01-24-2011 02:07 AM
Another problem I forgot to raised is that with the Vector DB Editor, it's not possible to create 2 frames with the same ID.
So I can't even ask my customer to prepare his dbc in a manner I could work with, and It will be a lot of rework to modify and verify every frame in the actual dbc.
Thanks for your help.
Kind Regards,
01-24-2011 04:18 AM
yes this is a limitation of XNET driver I think, we didn't not find a solution to this probleme when using XNET dbc decoder.
Our solution is to use RAW frames with input/output streaming and to manage by ourself the decoding of the dbc and the scheduling of transmitted frameS...
01-24-2011 06:01 AM
Hi Pierre,
Thank you for your answer. I have not looked at Raw frames yet. That's a potential solution but which will cost a lot of work.
I keep this in mind, but if somebody thinks to another solution...
Thanks. CU
01-27-2011 03:05 AM
Finally There is two other possible options.
1- You can Stop a session and restart it immediately. In this way, the time you restart the session sends immediately a frame on the Bus, thus creating a kind of event frame.
The problem with this method is that your period is now synchronized with the reset of the session, not the original start.
2- You can create 2 sessions on the same Frame,a Single-Point session, and a Stream Session. The single point session will take care of the periodic behavior of the frame, than you can call a Write on the Stream Session to create the Event frame, because this mode doesn't take care of Timings in DBC.
Hope this could help anybody else.
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
