06-27-2013 02:02 PM
How does XNET determine the order CAN devices are numbered? For a PXI system, it does not seem to be the following:
In addition, the channels are not listed in ascending order for the XNET session controls.
06-28-2013 04:59 PM
How do your CAN Devices appear in MAX? What CAN devices are you connecting to?
If you create a constant on the block diagram of the channels do they give you the same order, random, or in ascending order?
07-01-2013 12:27 PM - edited 07-01-2013 12:28 PM
The MAX configuration is sorted by CAN channel where the XNET constant (same as control) channel order is not as seen below:
I would prefer not to post the device serial numbers in a public forum. Please let me know if I should continue this with a support request.
07-02-2013 05:55 PM
Thank you for that information. A Corrective Action Request, #415101, has been filed regarding this behavior. The best way to learn about the progress of the CAR is by contacting support after some time to get any updates.
