04-04-2019 01:38 PM
I'm using VeriStand 2017 with ECUMC 18.0 to communicate via XCP with my ECU and I've added a number of measurement tasks to the XCP Custom Device, some tasks using a "Read/Write Mode" of "Polling" and some using the "DAQ List" option. As I added more of these measurement tasks, I noticed that all the measurement tasks with the "DAQ List" mode selected would stop working. Digging through the XCP debug logs the custom device can generate, I noticed the XCP command "ALLOC_DAQ" would get called with an input equal to the TOTAL number of Measurement tasks I had defined, not just the tasks with the "DAQ List" mode selected. The ECU's code had a configured limit on the number of DAQ lists it was willing to support and I had crossed the line well before I was expecting to.
For example, if I had 3 measurement tasks with "Read/Write" mode set to DAQ and 3 with the mode set to "Polling", the "ALLOC_DAQ" message sent by the XCP Custom Device would "ALLOC_DAQ DAQCnt=6".
Is there a deeper reason all measurement tasks are included in this "ALLOC_DAQ" call? With my basic understanding of XCP, I would have expected only the measurement tasks with the "Read/Write Mode" "DAQ List" would to have space allocated.
04-09-2019 01:49 AM
Hi DerekTheRockRockson,
This is indeed a bug in the software. In your example, only 3 DAQ lists should be allocated. Thanks for bringing this to our attention. I filed a bug report and it should be fixed in one of the next versions of ECUMC.
The bug is that all measurement tasks in the session, whether they are configured as a DAQ list or with polling, are used to request DAQ lists if at least one of them is configured as a DAQ list. Currently, the only way around this is to use only one of them, DAQ lists or polling. I recommend DAQ lists because it requires less traffic to communicate the same information.
Kind Regards,
Tim
04-10-2019 02:21 PM
Hello Tim,
Thanks for filing that bug report for me. Its good to know that my intuition is correct. And thanks for the fast reply!
-Derek
08-14-2019 10:50 AM
Hi Tim,
Could you please provide the CAR number?
Thanks!
David
09-12-2019 02:48 PM
For those interested, this is ECU MC Toolkit CAR 734080.
