05-28-2020 09:18 AM
Hello
I am having an issue with the last version of the X-NET 20.0. Can you check the frame generation with the X-NET 20 for a signal with an scaling less than 1?
I attach a picture with the problem
05-28-2020 10:05 AM
I too want to hear NI's response, especially since I didn't know 20 was out already. But I did just test this with my conversion library posted here and it does handle it properly creating the D5. The benefit of mine of course being written in pure G is you can debug it and figure out why a conversion would be wrong.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
05-29-2020 02:33 AM
Thanks for your answer.
I will check your library.
One problem we are having speacilly with CAN communication (ECU Measuremeent Tookit) is that the code cannot be debugged and seen, and as soon as some automotive parts we are working with are in "alpha" version, the CAN behavoir is not as expected and Labview generates some errors.
Since the library is a black box we cannot modify any code.
06-24-2020 06:40 AM
Hi Henoc.
I am not seeing the same behavior with NI-XNET 20.0. Database file and VI used are attached.
Perhaps can you provide a simple example for us to reproduce the issue?
May be you want to try repairing the driver?
DISCLAIMER: The attached Code is provided As Is. It has not been tested or validated as a product, for use in a deployed application or system, or for use in hazardous environments. You assume all risks for use of the Code and use of the Code is subject to the Sample Code License Terms which can be found at: http://ni.com/samplecodelicense
07-06-2020 06:13 AM
Sorry for my late reply. I tried with other computers and works ok. I think the problem comes with the region/language of the operating system.
At the moment, i just changed the computer. As soon as I have some time, i will investigate this issue further (since only happen with one specific a2l and in one computer configured in spanish)
Thanks for your answer and support.
Regards
Henoc
