12-18-2017 02:32 AM
I have very general question about creating two separate buses in vector CANOE so I could manually route messages between them.
So far I thought I ought to create 2 separate networks (HS1 and HS2) with one of Nodes present in both so gateway symbol appears on it but I ran configuration below where node HS1_ECU1 output some message with example id 0x42. Node ECU2 sees this message ( on message 0x42 event within ECU2 ) but to my surprise this message appears on network HS2 as well (on message 0x42 within node ECU3) so this does not do what I thought it do.
So what is the correct way to create to separate buses in canoe? I mean virtual buses only without any hardware involved.
Thank you for your help.
12-27-2017 04:18 AM
Hi Twar,
This is not an NI product, thus you should rather turn to Vector Tech Support instead: https://vector.com/vi_support_en.html
They should be able to help you.
