02-10-2018 11:40 AM
Hi all,
Would it be possible to extend the number of chip select (8) of a 8452 module by using the DIO lines of the 8452 and SPI script ?
If yes what are the caveats and recommendations ?
S. Michaud
Solved! Go to Solution.
02-12-2018 04:33 AM
Hi all,
Any help from anybody ?
Thx,
02-12-2018 11:47 AM
Based on the scope captures I took today it should be possible to script a DIO line to emulate a CS line. There are minor differences in how the CS and DIO lines behave outside of the script. For example, the SPI Script Disable.vi will tristate the SPI lines in between scripts where the DIO will remain in the last state it was programmed to be in.
02-12-2018 11:54 AM - edited 02-12-2018 11:55 AM
You bumped your own thread after 19 hours, after posting at midnight Sunday, on the US east cost, in a subforum for automotive help, asking about SPI hardware. Please be more patient, next time, post in the correct subforum, and realize the large majority of people here are volunteers. If you need immediate help contact NI, or pay a contractor for help.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
02-12-2018 12:28 PM
Thank you very much
02-12-2018 12:33 PM
SPI is mentioned only above Automotive section.
Maybe it would be better to classify it elsewhere ?
02-12-2018 12:50 PM
Is it? If so I apologize. I would have thought Instrumentation Control, or Digital I/O would have been more appropriate.
