06-07-2018 01:14 AM
Hi all.
I have simply program for testing of CAN signals. On port 1 i write some generated values and on port 2 i'am reading same values. I am using Single point reading and writing.
After first write I read only default values. On second read I read the values from the first write, but i need to read the actual values for comparing.
Thx for solution.
06-07-2018 02:52 PM
Single point session types will provide you with the most recently received value. If no value has been received, single point will return the default value. If two or more frames were received between reads, only the last will be returned and the others will be lost.
In order to avoid reading default values you need to do two things. First, you need to explicitly start the input session so that it can receive data before the XNET Read.vi is called. Secondly you need to implement some mechanism, whether it be data flow with error wires, a state machine, or something else, that ensures the XNET Write.vi is called before the XNET Read.
If you post some screen shots of your code or attach the VI we can probably provide additional help.
06-11-2018 09:00 AM
As JefeL said you'll want to use the right session type and the right way. Here is a blog post I made discussing the different XNet session types and why you might choose which ones. Also know you can use multiple sessions at the same time to get the best of all the available session types.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
06-15-2018 12:23 AM
Thx a lot to all.
Finally I'am used frame stream and problem is solved. In my case it doesn't matter which type of session I used.
Once again
Thx a lot.
06-18-2018 08:15 AM
It does matter, they function differently and server different purposes. I'm glad it is working for you but you should research the different session types and understand when to use which one.
