11-15-2018 07:21 AM
Hello it is my first post here so hello everyone 🙂
I have a problem with USB-8476S and LIN network. I have everything connected just fine because under another hardware it works perfectly. Although I want to do it in LV. I am using LIN Master send Full Frame and Receive.vi and getting the same message again and again no matter which frame I write. Could someone just write me what should I write to Data array to make it responding? ID of my slave is 0x3. That's all my documentation says.
01-14-2019 05:37 AM
Hello Pawlo03,
so you changed Hard- and Software and now it does not work?
What Hard- and Software were used when it was working?
Have you tested your setup with the build in examples for the USB-8476S?
Best wishes
