12-21-2021 10:31 PM
I have a question, I would like to know if the USB8506 1Port and 2Port are compatible with each other or use separate drivers.
12-22-2021 07:19 PM
USB-8506 regardless of one-port or two-port variants are supported under the same NI-XNET driver and use the same API.
DISCLAIMER: The attached Code is provided As Is. It has not been tested or validated as a product, for use in a deployed application or system, or for use in hazardous environments. You assume all risks for use of the Code and use of the Code is subject to the Sample Code License Terms which can be found at: http://ni.com/samplecodelicense
